DAQmx Buffer Size Allocation for Finite or Continuous Acquisition
Updated Jul 10, 2026
  • How does DAQmx allocate buffers?
  • How large is my acquisition buffer?
  • How do I make my buffer size larger?
With NI-DAQmx, memory allocation for input/output tasks is typically handled automatically for you in the DAQmx Timing Function for LabVIEW, see DAQmx Timing (Sample Clock) VI.
Input Tasks:
  • If the acquisition is finite (sample mode on DAQmx Timing function is set to Finite Samples), NI-DAQmx allocates a buffer equal in size to the value of samples per channel.
  • If the acquisition is continuous (sample mode on the DAQmx Timing function is set to Continuous Samples), NI-DAQmx allocates a buffer equal in size to the value of the samples per channel attribute/property, unless that value is less than the value listed in the following table. If the value of the samples per channel attribute/property is less than the value in the table, NI-DAQmx uses the value in the table.
Sample RateBuffer Size
No rate specified10 kS
0-100 S/s1 kS
101-10,000 S/s10 kS
10,001-1,000,000 S/s100 kS
>1,000,000 S/s1 MS
Note: You can override the default buffer size by calling the DAQmx Configure Input Buffer VI.
Output Tasks:
For an output task, the amount of data you write before starting a generation determines the size of the buffer. The first call to a Multiple Samples version of the Write function/VI creates a buffer and determines its size.
You also can use the Output Buffer Config function/VI to create an output buffer. If you use this function/VI, you must use it before writing any data.
The samples per channel attribute/property on the Timing function/VI does not determine the buffer size for output. Instead it is the total number of samples to generate. If n is your buffer size, setting samples per channel to 3×n generates the data in the buffer exactly three times. To generate the data exactly once, set samples per channel to n.
This information can all be found in the NI-DAQmx Help documentation. In Windows, you can find this documentation by going to Start»Programs»National Instruments»NI-DAQmx Documentation. In the help file, this specific information is located in the Buffering section under Key NI-DAQmx Concepts. Along with this topic, many other common questions and problems can be answered through the information in this help file.
