このコンテンツは設定された言語で表示できません。
Cursor Appears Incorrectly Using LabVIEW on 4K Monitor
Updated May 9, 2023
  • LabVIEW Base
  • LabVIEW Professional
Other
  • Windows 10
  • LabVIEW 2017 32 bit
  • LabVIEW 2018 32 bit
  • 4K monitors
  • My mouse appears shrunken. I am using LabVIEW 2017 in Windows 10 on a 4K monitor, and my cursor is shrunken when I am in the block diagram or the front panel. The cursor works fine in other LabVIEW menus and toolbars.
  • My mouse is enlarged. I am using LabVIEW 2018 SP1 in Windows 10 on a 4K monitor, and my cursor is enlarged when I am in the block diagram or the front panel. The cursor works fine in other LabVIEW menus and toolbars.
Certain high-resolution computers may experience this problem with a shrunken or enlarged cursor while using LabVIEW.
Shrunken: There has been a bug fix implemented in 2018 SP1, ID 677536. This bug is fixed in LabVIEW 2018 SP1 but this may still be an issue in previous versions.
Enlarged: This is a known issue in LabVIEW 2018 SP1 and later, and it has been reported to NI R&D. Corrective Action Request (CAR) number is 740315.
The following workaround can be used to stop the controller from appearing shrunken or enlarged in both cases:
  • Set the display settings to 100% scaling and 1080p resolution
  • Use a secondary lower resolution monitor for LabVIEW.
To implement this workaround, navigate to the following: Start > Settings > System > Display
