Error Occurs When Running LabVIEW
- Uninstall the National Instruments software from your computer.
- Clean the computer's cache
- Download and install your software again from ni.com (If you're using multiple toolkits/drivers, remember to install LabVIEW first, and secondly the add-ons you have. Failure to install in proper order might result in missing toolkits/pallets)
NOTE: It's important to download the software again from the National Instruments' website, since the media and/or download used previously might have been corrupted, causing the error to show again after repeating this process.
Error Occurs When Running a LabVIEW Executable
- Ensure that the bitness of the LabVIEW Run-Time Engine that the executable was built in, is compatible with the bitness of the operating system. For example, if you have an executable built in 64-bit LabVIEW, it will not be able to run on a 32-bit Operating System or on the 32-bit LabVIEW Run-Time Engine and you'll encounter an error
