I'm collecting data on multiple cDAQ chassis in SignalExpress. I can acquire data on one chassis with no problem, but when I try to acquire on multiple chassis I get the following error:
Error -201483 occurred at DAQ Assistant
Possible Reason(s):
The selected master for the configured multi-device task is not able to export signals. Make sure that the first channel in the task is from a device on a chassis that has an NI 9469 capable of exporting signals to the slave devices. If you have any delta-sigma modules in your task, at least one must be in the master chassis..
However, I am not using an NI 9469 module. How can I avoid receiving this error?
