Why Is the Function Generator Output Amplitude Doubled in NI Multisim?
Updated May 1, 2018
  • Multisim Base
  • Multisim Full
  • Multisim Professional
  • Multisim Education
I set the function generator to output a 1 Vpeak sine wave, but when I acquire the signal with a scope, I am reading 2 Vpeak. Why is the output of the function generator twice as large than what I set and how can I correct it?
To avoid this behavior, ensure your function generator is connected as shown in the image below.
The function generator has three terminals, positive output, negative output and a middle reference terminal. The negative output terminal generates the opposite polarity as the positive output pin; therefore, if you connect the circuit ground to the negative output you will get a signal with an amplitude two times larger than what you set. Instead, you should connect your circuit ground reference to the middle reference terminal of the Function Generator.
