This may be caused by a recently discovered incompatibility between the BIOS and NI drivers. This issue has been observed on some recent machines featuring dual-core processors, although single-core machines may still be affected. Some machines that are known to reproduce this issue are:
- Hewlett-Packard DC7700
- Hewlett-Packard DC5700
- Hewlett-Packard DC5750
- Hewlett-Packard DX7300
We have also found incompatibilities with custom-built computers using the following hardware:
- P6T WS Professional Workstation Motherboard
Please ensure that:
- You are using the latest BIOS for your machine.
- You are using the latest NI drivers for your device.
- Download and apply the Core Driver Update. This should only be needed if the latest NI Drivers or BIOS for your machine do not resolve the issue.
If you still encounter this issue after following the steps above, please contact NI support so that we can determine the root cause of the problem. NI is actively working with computer and BIOS vendors to resolve this problem.
