Error Code 10 in Windows Device Manager with NI PCI Devices
Updated Apr 29, 2025
Other
Known relative hardware for this issue:
  • Hewlett-Packard DC7700
  • Hewlett-Packard DC5700
  • Hewlett-Packard DC5750
  • Hewlett-Packard DX7300
I have installed the latest NI drivers, yet none of my PCI devices show up in NI-MAX. When I check the Windows Device Manager, the NI PCI devices have a yellow bang/exclamation mark and have received   This device cannot start. (Code 10)
This may be caused by a recently discovered incompatibility between the BIOS and NI drivers. This issue has been observed on some recent machines featuring dual-core processors, although single-core machines may still be affected. Some machines that are known to reproduce this issue are:
We have also found incompatibilities with custom-built computers using the following hardware:
  • P6T WS Professional Workstation Motherboard
Please ensure that:
  1. You are using the latest BIOS for your machine.
  2. You are using the latest NI drivers for your device.
  3. Download and apply the Core Driver Update. This should only be needed if the latest NI Drivers or BIOS for your machine do not resolve the issue.
If you still encounter this issue after following the steps above, please contact NI support so that we can determine the root cause of the problem. NI is actively working with computer and BIOS vendors to resolve this problem.
If the USB Sentinel SuperPro driver by Rainbow Technologies Inc. is installed on the computer, the Core Driver Update will conflict and cause the SuperPro driver to not function.
