Arduino Board Version and Arduino Interface for LabVIEW Toolkit Compatibility
Updated Mar 12, 2026
Other
Hardware: Instrument Connectivity
I already own an Arduino. Which Arduino boards are compatible with the Arduino Interface for LabVIEW toolkit?
The following devices are officially supported with this toolkit:
  • Arduino Uno
  • Arduino Mega 25260
  • Arduino Duemilanove
  • Arduino Nano
Though the toolkit has been used with other Arduino boards, only the boards listed above are officially supported by the Arduino Interface for LabVIEW.
If you do want to attempt to use another board, remember to choose the correct board in the Arduino IDE so that the Arduino I/O engine gets compiled down for the right board.
Also note that the Arduino Interface for LabVIEW Toolkit is no longer actively maintained. For up-to-date support for Arduino and other devices, consider using the LabVIEW Hobbyist Toolkit (formerly known as the LINX Toolkit).
