The Buzzer in Multisim Does Not Generate Any Audio
Updated Oct 14, 2022
  • Multisim Base
  • Multisim Full
When simulating a circuit using the buzzer component, there is no sound from the computer.
How can I get multisim to produce the buzzer sound using this component?
If You're Running Multisim on Windows Vista 64-bit or Windows XP 64-bit
This sound is no longer supported
If You're Running Multisim on Windows 7 64-bit or Later
You will need to install a driver for your sound card for you to be able to use the buzzer.
The reason for this problem is that the Windows beep() system function used by the buzzer is no longer supported in Windows Vista 64-bit or Windows XP 64-bit.
The buzzer plays through the sound card, it no longer plays through the motherboard like in earlier versions of Windows.
