NI Hardware Windows 10 Compatibility
Updated Dec 18, 2017
Other
Windows 10
My system needs to be updated to Windows 10. Will I still be able to use my NI device with that system?
Windows 10 compatibility of your NI hardware depends on its driver.
In order to find out if your NI device can still be used in Windows 10 follow these steps:
  1. Find out what drivers are required to operate your device (this information can be found in the Data Sheets or Getting Started Guides)
  2. Visit National Instruments Product Compatibility for Microsoft Windows 10
  3. Check the drivers table in section four for comments related to Windows 10 usage
In case you need to update your driver to a more recent version visit the NI driver download portal.
