What is Measurement & Automation Explorer (MAX)?
Updated Mar 26, 2019
What is NI Measurement & Automation Explorer (NI MAX)?
NI's Measurement & Automation Explorer (NI MAX) provides access to your National Instruments CAN, DAQ, FieldPoint, GPIB, IMAQ, IVI, Modular Instruments, Motion, NI Switch Executive, VI Logger, VISA, and VXI devices.
With MAX, you can:
  • Configure your National Instruments hardware and software
  • Back up or replicate configuration data
  • Create and edit channels, tasks, interfaces, scales, and virtual instruments
  • Execute system diagnostics and run test panels
  • View devices and instruments connected to your system
  • Update your National Instruments software.
MAX is a free piece of software that automatically installs with National Instruments software and device drivers.
Detailed, topic-specific help can be found in menu Help»MAX Help in MAX.
For questions about specific options press the show help button in the upper right hand corner of the window to show the sidebar help. Hovering over options will give descriptions in the sidebar help so that you know what each configuration means.
You can access information on the computer you are executing NI MAX on via Help»System Information. The data shown includes e.g. the version number of your operation system, the number of processors, and the available physical memory.
Version information about the version of MAX you are using is available at Help»Information.
If you need a driver for a particular hardware product, see National Instruments Hardware Drivers
