Programmatically Obtaining Names of all DAQmx Devices on a Machine
Updated Jan 11, 2023
When using the DAQmx driver, a default name is given to all devices when they are installed on the machine. Is there a way to obtain the device name for my connected devices programmatically?
The default DAQmx device names (i.e. Dev1, Dev2, cDAQ1, etc.) or those specifically assigned in MAX can be obtained using a property node.  The DAQmx System Property Node is located in the System Setup subpalette.
The DAQmx System Property Node contains a specific property called Device Names.
The Device Names property returns an array of all DAQmx devices recognized by MAX.
If a specific device name is desired, it can be parsed or removed from the array using the Index Array function in LabVIEW, shown in the VI snippet below.
