Este contenido no está disponible en su idioma de su preferencia.
El contenido se mostrará en otro idioma disponible. Su navegador puede proporcionar una funcionalidad para ayudarle a traducir el texto.
Execution Speed of While Loop on FPGA
Updated Oct 8, 2024
  • LabVIEW FPGA Module
I use a while loop in my FPGA VI and want to know the period of an iteration. How fast does my while loop iterate?
A common way to find out the duration of a loop iteration on FPGA is by benchmarking it with the Tick Count Express VI. By using this VI twice in addition to a shift register the duration of the iteration can be measured. This way every iteration the time passed is measured and compared with the time passed of the previous iteration.
The accuracy of your measurement depends on how you configure the Express VI. The VI does not respond with fractional numbers. This means that your choice of ms, µs, or ticks affects your accuracy. For example an iteration that takes 47.9 ms will result in a measurement of 47 ms.
