이 내용은 고객님의 설정 언어로 확인할 수 없습니다
Error -229770 at DAQmx Start Task on Ethernet compactDAQ Chassis
Updated Feb 11, 2025
  • cDAQ-9184
  • cDAQ-9185
  • cDAQ-9187
  • cDAQ-9183
  • cDAQ-9188
  • cDAQ-9181
  • cDAQ-9189
I can't drag my tasks from NI Measurement & Automation Explorer (MAX) into LabVIEW and the constant for DAQmx Start Task has no options. I am getting Error -229770 at DAQmx Start Task when I try to run it.
  • Check if the IP address is shared with another instrument.
  • If it has the same IP address as another device on the network, change the IP address to a unique one using this article: Configure a Static IP Address on Ethernet cDAQ
    • If this is the case, there will be a greyed out cDAQ chassis in NI MAX with the same name as the plugged in cDAQ chassis.
