LabVIEW Shared Variables are backwards compatible since LabVIEW 8.6.1 and can communicate successfully between different versions of LabVIEW and on separate computers on the same network. However, using different versions of LabVIEW requires communicating between multiple projects, so in order to achieve this, you can use programmatic communication with the Shared Variable API or you can bind the shared variable.
Refer to the Shared Variable.lvproj example project in the Example Finder, located in
Browse (according to Task) »
Networking »
Shared Variables, and to Reading and Writing Shared Variables Programmatically in the LabVIEW Help for further details.
Another option is to bind the NI-PSP data item (shared variable on another computer) to the shared variable you would like to use in your project. For more information, refer to the
 Enable Aliasing section in the
Variable Page (Shared Variables Property Dialog Box)
