Select Values to Store with DAQmx Configure Logging (TDMS) VI
Updated Sep 27, 2023
I do not want to stream all the values acquired with my NI DAQ Device to the hard drive. How do I configure DAQmx Configure Logging (TDMS).vi to only stream the values I want?
The DAQmx Configure Logging (TDMS).vi does not include the function to stream to the hard drive selectively. In the case that you need to manipulate, select or order the acquired data you have the following options:
  • Use a combination of the DAQmx Read VI and VIs from the TDMS API. However, the tradeoff here is that the data will not directly move from the buffer to the hard drive.
  • Use the TDMS API to load your data after it has been saved to the hard drive. You can edit your data and create an updated Log file.
