'No Such Interface Supported' When Adding C Series Module to CompactRIO Chassis
Updated Jan 5, 2018
  • LabVIEW Base
  • LabVIEW Professional
I have successfully setup my CompactRIO and have added it to a project, but when I add a C Series Module to the chassis, I get the following message:
System Error &H80004002 (-2147467262)
​No Such Interface Supported
This error occurs when the incorrect versions of either LabVIEW,  LabVIEW RealTime Module, or NI-RIO are installed for the specific hardware being used. To resolve this issue you must check the minimum versions software that support your hardware and verify that they are installed.
You can find the minimum required software versions at the Software Support for CompactRIO, CompactDAQ, Single-Board RIO, R Series, and EtherCAT website. To determine the versions of the NI Software Installed on your computer refer to the Determine the Version of the NI Software Installed on My Computer article.
