Yes, this can be done statically by configuring the module from within the LabVIEW Project Explorer or dynamically in the LabVIEW environment. See
Software Support for CompactRIO, CompactDAQ, Single-Board RIO, R Series, and EtherCAT for supported modules and follow the steps below to perform PWM under the RIO Scan Interface.
1. Once the module has been added to the scan interface as shown in the image below, right-click on the module, then select
Properties.
2. When the C Series Module Properties configuration window is visible select
Specialty Digital Configuration from the Category window, then select
Pulse-Width Modulation from the
Speciality Mode window. Now you will be able to select the
Frequency of the PWM signal for each channel, as shown in the image below.
