Connecting a PXI(e) Chassis to an External PC via MXI(e)
Updated Oct 22, 2025
  • MXI Cable
  • PXI Chassis
  • PXI Remote Control Module
  • PCIe Interface
Other
  • 3rd Party Desktop or Rackmount PCs
Throughout this article, you will learn how to control your PXI(e) System with a 3rd-Party desktop or rackmount PC using an MXI(e) kit (PXI(e) Remote Control Module + PCI(e) Host Interface Card + MXI(e) Cable) instead of using a PXI(e) Embedded Controller.
A PXI(e) chassis can be connected to a desktop or rackmount PC using a pair of PXI(e) and PCI(e) cards as shown below:
 Follow the next steps to control your PXI(e) System with a desktop PC (skip steps 1-3 if you already have an MXI(e) kit):
  1. Acquire a PXI(e) Remote Control Module that is compatible with your system:
  2. Acquire a PCI(e) Host Interface Card that is compatible with your PXI(e) Remote Control module.
  3. Acquire an MXI(e) Cable to connect your PXI(e) Remote Control Module to the PCI(e) Host Interface Card.
  4. After receiving your MXI(e) kit, refer to the section Set Up your MXIe System in the documentation attached above.
Some PXI(e) chassis (like the PXI-1033 or the PXIe-1073) have an integrated MXI(e) controller. This means that these chassis don't require an additional PXI(e) card as they already have an MXI(e) interface on the back. In this case, all you will need is the PCI(e) card for your host PC and an MXI(e) cable that are compatible with your PXI(e) Remote Control Module.
Note –  In order to connect your PXI(e) chassis over MXI(e) to your PC, the computer must have a PCI or PCIe slot (whether the required slot is PCI or PCIe depends on the particular Host Interface Card you will use) to accommodate the PCI(e) Host Interface Card.
To check for hardware compatibility, you can either build your system using the NI PXI Advisor or use the table below:
