Wiring considerations for the NI 9237 module
Updated Nov 27, 2017
  • NI-9237
I am looking to wire a load cell to the to NI 9237 module. Are there any specific wiring cables or accessories that I will need in order to accomplish this?
You will need to use a NI 9949 which is a RJ 50 to Terminal Block Accessory. This will allow you to wire the loadcell to the terminal block which you can then wire to the NI 9237 C Series Strain/Bridge Input Module.
Detailed information on wiring can be found in the Getting Started Guide for the NI 9237 and the NI 9949 RJ-50 to Screw-Terminal Accessory Guide
