If Using In Scan Interface1. Make sure that you have the minimum required software:
- LabVIEW 2010
- LabVIEW Real-Time Module 2010
- NI-RIO 3.6
- NI-VISA
- NI-Serial 3.7 Driver
2. Install the
NI-Serial 9870 and 9871 Scan Engine Support and
NI-Serial RT to your real time controller.
3. Add the module to your LabVIEW project (see example picture below).
If Using In FPGA Interface1. Make sure you have the following minimum required software:
- LabVIEW 8.5
- NI-RIO 3.0
- LabVIEW FPGA Module
2. Follow the standard procedure for
adding modules to a FPGA target (see the picture below).
When using the module in Scan Interface Mode there will not be ports under the module in the hierarchy on Project Explorer. Although the ports do not appear in the project they will still show in VISA IO Nodes on the front panel and block diagram. You may configure the ports from Measurement & Automation Explorer or programmatically using NI-VISA.
There is also a
limitation on the maximum baud rate that can be achieved with these modules when used with Scan Engine.
The RIO Scan Interface is a FPGA intellectual property (IP) developed by National Instruments that is downloaded to the CompactRIO FPGA and is responsible for I/O module detection, timing, synchronization, and communication. For more information on RSI requirements, refer to
this article.
