Some ActiveX Methods and Properties are Grayed Out
Updated May 3, 2018
  • LabVIEW Base
  • LabVIEW Professional
When I right-click an ActiveX method or property, why do some entries in the list of available methods/properties appear dimmed (grayed out)?
A method or property is unavailable if it is passing a data type that is not supported by the ActiveX standard. For example, if the method or property uses complex data types, they might not be supported.
To make the method or property available again, switch it to a supported data type. Refer to Microsoft ActiveX support for more information.
