Connecting a CompactRIO, Compact FieldPoint or PXIController to a Wireless Network
Follow the steps outlined below:
- Configure the wireless router by following the instructions provided by the wireless router vendor. If you already know your controller's IP address skip to step four.
- Connect the host computer to the network. (The host computer is required to configure the controller's IP address for the first time)
- Configure the controller by first setting up a unique IP address from the host computer.
- For this step, connect the controller to the network via ethernet cable.
- Open NI Measurement and Automation Explorer (MAX) on the host PC and select the CompactRIO, Compact FieldPoint or PXI controller under Devices and Interfaces>>Remote Systems, which should be automatically recognized by the network.
- After an IP has been assigned, disconnect the controller from the network by removing the ethernet cable.
- Next, the wireless ethernet adapter must be assigned to an unique IP address. Follow the instructions provided by the wireless ethernet adapter vendor to assign an IP address (it may be assigned automatically, or you may need to use the host computer to do this).
- After both the controller and the wireless ethernet adapter each have their own IP address, connect the two together by using a standard ethernet cable.
- Verify that the controller is communicating properly by going to Measurement and Automation Explorer (MAX) and checking for the device under Devices and Interfaces>>Remote Systems. It should appear with the same IP address that was assigned above (step 2). However, this time it won't be physically connected to the network, but instead through the wireless ethernet adapter.
If you run into problems finding your CompactRIO, Compact FieldPoint or PXI controller in MAX please follow this KB: NI CompactRIO or Network Device Doesn't Show Up or is Missing in MAX
Required Network Equipment
In order to provide your Ethernet-equipped CompactRIO with instant wireless networking capabilities, you will need the following network equipment:
- Wireless Router
- Wireless Ethernet Adapter
When purchasing an ethernet router and adapter, you may choose any ethernet networking standard you wish. The CompactRIO controller uses a standard 10/100 ethernet port. If speed is a consideration, purchasing equipment that utilizes the 802.11ac standard is recommended over 802.11g or 802.11b because it provides you with networking speeds nearly eight times faster than that of 802.11g and is backward-compatible (see Table 1 for communications rates):
Table 1. Communication Rates for Different Network Protocols
| Network Protocol | Communication Rate |
| 10Base-T | 10 Mbps |
| 100Base-T | 100 Mbps |
| 802.11b | 11 Mbps |
| 802.11g | 54 Mbps |
| 802.11ac | 433 Mbps |
Note: Mbps stands for millions of bits per second and is a measure of bandwidth (the total information flow over a given time) on a telecommunications medium.
