Receiving Error -200369 when Adding Ethernet Connected cDAQ in NI-MAX
Updated May 3, 2018
  • cDAQ-9185
Other
Windows 7
I'm connecting my cDAQ-9185 to the network via an ethernet switch. NI MAX can detect it as a network device, but when selecting "Add Device," I get error -200369. The device also shows up in the NI Web-Based Configuration and Monitoring tool.
This error can occur when you're trying to add a device with a hostname that might already be in use somewhere else on the network.
To see your device in MAX:
  1. Change the host name of your device in the Web-Based Configuration and Monitoring tool.
  2. Restart your device for the hostname change to take effect.
