NI-488.2 for Linux 15.1 Fails to Install
Updated Nov 22, 2017
  • NI-488.2
  • NI-488.2 15.1
  • NI-488.2 15.1.1
I am trying to install NI-488.2 for Linux 15.1, and my install is failing.
Uninstall any previous versions of NI-488.2, and install NI-488.2 15.1.1.
NI-488.2 for Linux 15.1 has a known issue which will cause an installation to fail if NI-PAL and NI-KAL versions 15.1 or later have already been installed. NI-488.2 for Linux 15.1.1 is a patch released specifically to address this known issue.
If NI-488.2 version 15.1 is already installed on a system, installing 15.1.1 will have no effect. You should manually uninstall previous versions of NI-488.2 before installing version 15.1.1.
