Required RIO Device Drivers for LabVIEW 2015 and Later
Updated Nov 20, 2019
  • CompactRIO Controller
  • NI-RIO
  • NI CompactRIO
  • NI-RIO
I have a RIO device and I'm not sure what driver I'm supposed to use. What driver do I need for my RIO device and where can I download these drivers?
CompactRIO and sbRIO Targets -  Install NI CompactRIO 15.0 or later depending on the version of LabVIEW you are using.
R Series Multifunction RIO devices - Install NI R Series MultifunctionRIO 15.0 or later depending on the version of LabVIEW you are using.
FlexRIO devices - Install NI FlexRIO 15.0 or later depending on the version of LabVIEW you are using.
Note: There may be special cases where you will need to install multiple device drivers depending on the hardware being used. For example, if you are using using the NI 9151 Expansion Chassis with a R Series device. you will also need the CompactRIO Device Driver to use C Series Modules within the 9151 chassis.
You can find the compatibility between versions of NI-RIO and LabVIEW on NI-RIO and LabVIEW Version Compatibility.
With the release of LabVIEW 2015 the NI-RIO Device Drivers have been divided into 3 separate distributions to better support customers using those specific devices.
