When I add or remove another USB device, or when I have been using a USB DAQ or cDAQ device for an extended period of time, I get Error -50808. The error may occur within 30 minutes or after multiple days of usage before the device stops communicating. Resetting the device or restarting the task results in the same error:
Error -50808 occurred.
Possible reason(s):
NI Platform Services: A USB transfer failed due to a transaction error reported by the USB host controller. This may be due to a fault in the system's USB host controller, a USB cable, or a USB device.
Task Name:
The error is shown in the following dialog box.
Note: In DAQmx version 9.3.5 and earlier Error -50405 occurs instead.
