Programmatically Obtain a Computer's and Target's IP Address Using LabVIEW or LabWindows™/CVI
Updated Feb 4, 2026
  • CompactRIO Controller
  • CompactRIO Chassis
  • LabVIEW Base
  • LabWindows/CVI Base
  • LabWindows/CVI Full
How to programmatically read the IP address of my computer using LabVIEW or LabWindows™/CVI?
Additionally, How can I get the IP assigned to Target in LabVIEW?
LabVIEW​​​​
  • Use the String to IP function from the TCP palette. Leave the name input empty if you plan to get the IP network address of the current machine.
  • To obtain all IP addresses of the computer, right-click the String to IP VI and select Multiple Outputs.
  • Using the String to IP functions, DHCP IPs assigned to Target can be obtained.
LabWindows™/CVI
  • ​​Call the GetTCPHostAddr function.
  • To obtain all IP addresses of the computer, call GetALLTCPHstAddresses.
The following example shows how to implement this in LabWindpws™/CVI. This is accomplished by passing an address of a pointer to pointer to a char variable. The library allocates an array of strings which must be freed using the TCPFreeMemory function.
char ** addresses = NULL;
 int numAddresses;
 int index;
 GetAllTCPHostAddresses (&addresses, &numAddresses);
 /* Use the address strings... */
 for (index = 0; index < numAddresses; index++)
 /* Free address string */
 TCPFreeMemory (addresses[index]);
 /* Free addresses array */
 TCPFreeMemory (addresses);
To convert the IP addresses to dotted decimal notation or machine name, place an IP to String function on the block diagram. Wiring a true constant to the dot notation terminal will return the IP address in dot-notation format. Dot-notation format returns an IP address in the form 128.0.0.25. If the dot notation terminal is left unwired, or if a false constant is wired to it, it returns the IP address in the form machinename.domain.com.
