Receiving Error 7 When Deploying TestStand System
Updated Nov 21, 2017
  • TestStand 2016
Other
Operating System: Windows 7
I am attempting to deploy a test in TestStand 2016. After rebuilding that system, I am now getting an error 7. However this test will run successfully in TestStand 2016 and a sequence analysis does not generate any fatal errors that would prevent running the test.
  • Check files paths for instrument libraries
  • Replace removed VIs from instrument driver library. There have been documented cases in which removing VIs from the library can result in a build failure
  • If using Packed Project Libraries (PPLs) be sure to correctly deploy. The following instructions explain this: Deploying VIs in LabVIEW Packed Project Libraries
