Unable to Reset Configuration Database in Measurement & Automation Explorer (MAX)
Updated Mar 17, 2023
I would like to reset my configuration database in NI Measurement & Automation Explorer (MAX). However, when I select Tools >> Reset Configuration Data, nothing happens.
Why can't I reset the configuration database when I click this menu item?
This is a known and documented issue that can present itself on computers running Windows 7 64-bit with version 4.5.2 of the .NET Framework installed. The problem should not occur if the version of Windows is Service Pack 1 or later.
The ideal solution to this problem is to upgrade your computer to a more recent version of Windows 7 (i.e. SP1 or later), in order to install a more recent version of the .NET framework.
However, there is also a quicker workaround available to users who do not wish to upgrade Windows. You can reset the configuration database using a standalone executable that is provided with NI MAX.
 For more information on this workaround, see How Can I Reset the MAX Database Without Opening NI MAX?
