IEPE Sensor and Non-IEPE Sensor On the Same Card
Updated Nov 21, 2017
  • NI-9234
I have a few IEPE sensors and a few non IEPE sensors that I want to use on the same DAQ card. Is this possible?
If you are using a DAQ card that supports the use of IEPE sensors, you can read both non IEPE and non IEPE sensors on it. The IEPE functionality is software selectable for each channel. Instructions on how to do this in LabVIEW can be found here.
