ActiveX Error When Configuring TestStand Sequence
Updated Nov 17, 2017
  • TestStand 2010 SP1
Other
Software: TestStand 2010 SP1
OS: Windows 7
My program is suddenly returning an ActiveX Error when I attempt to bring up the Configure > Report Options within Sequence Editor. The error code is Code=0xffffbd97 with a description of 'Program Error'.
The INI file for TestStand is likely corrupted. Either replace it with an INI file from another test station, or delete the INI file and run a repair of TestStand.
