How do I Add VIs from Instr.lib in a Teststand Step?
Updated Nov 16, 2017
  • TestStand 2014 SP1
I want to use VIs from a LabVIEW library, specifically from the instr.lib in a TestStand step. How do I point to these in the step settings of a LabVIEW test step?
There are a couple ways to do this:
  • If you are looking to access a specific VI, you can call the VIs directly from the public folder
  • If you would like to have access to all of the VIs in the instr.lib folder you can add it is a search directory in TestStand. You can do this by selecting Configure>>Search Directories and click Add to add a new search directory.
More information about adding search directories can be found in the help article on Search Directories
