Error -1074360293 occurred at IMAQdx Get Image2.vi Possible reason(s): Timeout.
The error doesn't specify the exact reason of why the issue appears, in order to cover all the grounds please follow the recommendations below:
In case that in one of these steps mentioned above you encourage with the Error -1074396159, please navigate to Error -1074396159 Not Enough Memory for Requested Operation While Using NI-IMAQ/IMAQdx VIs , and follow the steps described there.
