Performing Pulse Generation with Counters on the USB-6008/6009
Updated Apr 1, 2025
  • USB-6009
  • USB-6008
I have an NI DAQ card with counters, for example the NI 6602. The counters on the NI 6602 can do pulse generation. I have tried to do the same with the counters on the USB-6008 or USB-6009 but I cannot figure out how. Can the USB-6008 or USB-6009 do pulse generation?
No, the USB-6008 and USB-6009 only support edge counting on their counters. Many counters on NI DAQ cards have the ability to generate a pulse train. This requires a counter gate and a counter source, which is explained more fully in the White Paper linked below.
The counter gate is not accessible on the USB-6008/6009 devices. These devices can be used ONLY for simple event counting using PFI0 as an event counter input.
For more information on the DAQmx API, see the DAQmx Documentation found at Start » Programs » National Instruments » NI-DAQ.
