Which IP Configuration Should I Use for My Ethernet Instruments?
Updated Mar 24, 2026
  • Ethernet Device
  • PXIe-8285
  • PXIe-8245
  • PXIe-8240
  • PXI-8232
  • PXIe-8238
  • PXIe-8280
  • PXIe-8290
  • I have a Desktop Ethernet instrument, and I don't know if I should use a DHCP or Static IP address to connect to it.
  •  I have a PXI(e) Ethernet Interface Module. How do I configure the IP address settings?
There are two different ways to connect to a Ethernet Instrument: automatically and manually.
In Microsoft Windows these settings are accessible through Change adaptor settings in the Network and Sharing Centre.
To determine which IP address type should be used:
  • DHCP (Automatic) - When your instrument is connected to a network with a Router or Hub, Use this setting to have the IP address dynamically assigned. This is the most common default state.
  • Static IP Address (Manually) - Use this when your instrument is either connected to a network with a switch or directly to your computer with a crossover cable.
Figure 1: Configuring the IP Address Automatically (DHCP)
Figure 2: Configuring the IP Address Manually with a Static IP (example address)
