このコンテンツは設定された言語で表示できません。
Go to
Control Panel»Add or Remove Programs»National Instruments IVI Specific Drivers
and click on Change/Remove.
Highlight the driver you would like to uninstall and click Remove.
For LabVIEW Plug and Play instrument drivers, go to
<National Instruments>\LabVIEW\instr.lib
and delete the folder that contains your instrument driver.
For CVI drivers, delete the directory that contains your instrument driver. The user can place these drivers in any directory, so it is up to the user to know where this directory resides at on the computer. The recommended installation location for CVI drivers is
<National Instruments>\CVI\inst.
A valid service agreement may be required, and support options vary by country.
