IPC 2221A/2222 Naming Convention for RLC Components in NI Multisim
Updated Aug 19, 2026
  • Multisim Base
  • Multisim Student 9
  • Ultiboard Full
Selecting the footprint in Multisim with the dimensions for Ultiboard before placing a resistor, inductor or capacitor. In the Select a Footprint dialog, Manufacturer/Type window shows IPC 2221A/2222 with a dimension, what is the naming convention for this?
Through-Hole Components (IPC 2221A / 2222 Standard)
The IPC 2221A / 2222 naming convention in Multisim and Ultiboard applies specifically to through-hole (leaded) RLC components.
    • Naming Structure: [Prefix] [Pin Distance]-[Body Length]X[Body Width]
    • Prefixes: RES (Resistor), IND (Inductor), or CAP (Capacitor).
    • Units: Values are expressed in millimeters (mm) with two significant digits.
    • Dimensions:
      1. First Number: Center-to-center pin distance (pitch).
      2. Second Number: Body length.
      3. Third Number (after 'X'): Body width.
Example:
The footprint name IND 1400-800X350 represents an inductor with
  • Center-to-center pin distance: 14.00 mm
  • Body length: 8.00 mm
  • Body width: 3.50 mm
Physical Component Case Sizes & Manufacturer Datasheets
Please note that National Instruments provides standardized land pattern geometry based on IPC specifications, but NI does not define physical component case sizes or tolerances.
Exact physical dimensions, height profiles, and land pattern recommendations for specific surface-mount capacitors should always be verified directly from the third-party component manufacturer’s datasheet (e.g., Kemet, Murata, TDK, Vishay).
For full details on IPC-7351A-compliant land patterns and footprint naming formulas used in Ultiboard, refer to Chapter 4: Working with Parts (Section: IPC-Compliant Land Patterns in Ultiboard) in the NI Ultiboard User Manual.
