This error occurs when the developer of a VI has removed the block diagram. Depending on whether the developer is 3rd party, there are a few different ways to resolve this error.
If you or your company created the code:
- Find the source code. There will be a LabVIEW project with a source distribution, similarly to the image below:
- The VIs listed within this project will still have their block diagrams, so use the one(s) that are required. You can navigate to a VI's location on disk by right-clicking the VI >> Explore...
If the code was created by a third party:
- Verify that the third-party component you are using is compatible for the LabVIEW year and version you are using (32 or 64-bit).
- If a matching version of the toolkit is available, use that instead.
- Try to contact the developers of the toolkit to see if they can upgrade it for you. Their product pages often have contact info provided, for example, PDF Toolkit for LabVIEW - Carya Automatisering provides an email in the Overview section
- Reinstallation of the 3rd party software solves this issue if the error is shown when the toolkit is already installed.
Note: Without access to the source code, the VI cannot be upgraded to a new LabVIEW version. Thus, NI cannot help with upgrading 3rd party toolkits that have VIs with their block diagrams removed.
