In order for the modules to appear under the chassis, please follow the steps below:
- Once you have selected the chassis, press the Add Device button.
- Reserve the chassis by pressing the Reserve Chassis button. You should now be able to see the modules.
- (Optional) You can now log in to the chassis by pressing Log In if you need to make any changes to its properties.
Once you have reserved the chassis in MAX, it may be necessary to run a self-test in NI MAX or reset the cDAQ chassis using the
Reset button in order to see the modules. Depending on your computer's network driver and configuration, a reset or self-test may also be required after restarting the computer.
Press
Restart in NI-MAX to restart the chassis. You should then be able to see the missing modules.
If it doesn't appear after these steps, check the minimum
driver version required for the modules.
