If you recently upgraded versions of LabVIEW, your VIs may need to be recompiled to run properly on your target. Follow the steps in
Forcing a VI to Recompile to do this.
If LabVIEW has not been upgraded and this error appeared after making changes to your code, this issue can often still be corrected by force-recompiling your VIs. If that does not change the behavior, you can attempt to resolve this by clearing the object cache in LabVIEW in order to ensure that everything is recompiled before deployment. There are two ways to do this:
- In LabVIEW, go to Tools >> Advanced >> Clear Compiled Object Cache.
- Delete the following file: C:\Users\<USERNAME>\Documents\LabVIEW Data\VIObjCache\<VERSION>\objFileDB.vidbe on disk.
