Using Global Variables to Share Data Between Projects and Executables
Updated May 20, 2026
  • I have built two LabVIEW projects, can I share data between them using a global variable?
  • I have built two LabVIEW executables, can I share data between them using a global variable that is not embedded in either executable?
Global variables cannot be used to share data across LabVIEW projects or executables.
This limitation exists because:
  • Each LabVIEW project or executable runs in its own application instance.
  • Each instance has an isolated memory space.
  • A global variable belongs exclusively to the memory space of the application instance in which it is loaded.
As a result:
  • A global variable in Project A is not accessible from Project B.
  • A global variable embedded in Executable A cannot be accessed by Executable B.
  • There is no mechanism in LabVIEW to create a “detached” global variable accessible across multiple executables.
Global variables are only suitable for:
  • Sharing data between VIs within the same project or executable
  • Simple data access where tight coupling is acceptable
However, there are other methods for communicating between projects or executables which are detailed below.
  1. TCP/IP or UDP
  2. Network Streams
  3. Communicate Between Multiple LabVIEW Executables Using Shared Variables
In order to figure out the best networking protocol for you, please consult our tutorial Using the Right Networking Protocol
