This specific behaviour is caused by linking to a system library by its path, rather than by the name of the library. Referring to the library by its path causes LabVIEW to include that path in the build specification of the executable, which will then cause a crash on execution.
To prevent this, go through the following steps
1. Double click on the
Library Function Node to access the configuration window
2. Change from using the absolute file path for the library or object you are calling to either the relative file path or just the library name.
For example, if you need to call
User32.dll, you could use either the absolute file path
C:\Windows\System32\user32.dll, the equivalent relative file path
%windir%\System32\user32.dll, or
user32.dll the within the
Call Library Function options menu. Either of the latter two will prevent this crash.
If using the relative path or the Library Name doesn't prevent the crash, you can also select Specify path on diagram in the configuration windows, as shown bellow :
In this case, in the path in input, you'll need to specify the library name in stead of the path to the library :
