To successfully install and run LabVIEW 2013 on Linux 64bit before the installation run the following commands in the terminal:
For Ubuntu 64bit (tested on version 14.04 LTS)
sudo suapt-get install lib32z1 lib32ncurses5 lib32bz2-1.0 lib32stdc++6apt-get install libxinerama1:i386 libgl1-mesa-glx:i386apt-get install xfonts-75dpi xfonts-100dpicp /usr/lib32/libbz2.so.1 /usr/libreboot
For OpenSUSE 64bit (tested on version 13.1):
sudo zypper install libXinerama1-32bitsudo zypper install -t pattern 32bitsudo zypper install Mesasudo zypper install Mesa-libGL1-32bit
For Scientific Linux (tested on version 6.5):
su rootyum install mesa-libGL.i686yum install libXinerama.i686
Once the components listed above installed follow the official
LabVIEW 2013 Installation Manual.
