Configure a Static IP Address on Ethernet cDAQ
Updated May 31, 2019
  • cDAQ-9181
  • cDAQ-9184
  • cDAQ-9185
  • cDAQ-9188
  • cDAQ-9189
  • cDAQ-9191
How do I configure my Ethernet CompactDAQ (cDAQ) device with a static IP address?
If your network admin imposes specific addressing requirements or if you are having trouble with a link-local connection between your Ethernet cDAQ device and your computer, you may need to configure a static IP address on your cDAQ device.
  1. Factory reset the Ethernet cDAQ device by holding down the reset button for more than 5 seconds. This will put the device into a default state and configuration. See the manual for the device-specific default configuration.
  2. Connect the Ethernet cDAQ device to the Ethernet port on your computer or the network you would like to connect the device to.
  3. In Measurement & Automation Explorer (MAX), expand My System»Devices and Interfaces. Right-click Network Devices, then Find Network NI-DAQmx Devices.
    Figure 1. Find Network NI-DAQmx Devices
  4. In the Available Devices list, select your Ethernet cDAQ device, then click Add Selected Devices.
    Figure 2. Add Selected Devices
  5. On the Network Settings tab (1), choose Static in the Configure IPv4 Address dropdown (2), and enter a local IP address (e.g. 192.168.2.10) in the IPv4 Address field. Click Save to apply the settings. You will lose connection while the device restarts.
    Figure 3. Network Settings
  6. Make sure the cDAQ chassis is connected to the same subnet as the one you just assigned to it. If you are using a Windows computer, you can find the subnet the device is connected to by connecting a computer to the network the device is using, running the ipconfig command, and looking at the IP address and subnet mask assigned by the router. The best way to insure the computer is on the same subnet by using a switch or using the same ethernet port the cDAQ chassis will be connected to.
  7. In MAX, under Network Devices, right-click your cDAQ device, then click Add Device.
