Reducing Glitches on the Analog Output of DAQ Devices
Updated Oct 12, 2020
  • PCI-6221
  • PCI-6251
  • NI-9262
  • NI-9263
  • NI-9269
  • NI-9264
I am using Analog Output channel on my DAQ device and I see random or periodic spike or glitches in my signal when reading it with a scope or an analog input channel. How do I overcome this issue?
These glitches are expected behavior provided they fall withing the Glitch Energy Specification of the device. Please refer to your devices specifications for information on what is the expected glitch energy. For example, here is the glitch energy specification for two devices:
PCI-6221:
Glitch energy
Magnitude ...................................100 mV
Duration .......................................2.6 μs
PCI-6251:
Glitch energy at midscale transition, ±10 V range
Magnitude ...................................10 mV
Duration ......................................1 μs
One some DAQ cards, you may see the glitch energy specified in units of nanovolt seconds (nV*s) rather than a magnitude and duration.
Some devices, such as the NI 9264 and NI 9263 will not have detectable glitching (cannot be picked out from the noise). Others, such as the NI 9262 and NI 9269 as well as X Series multifunction DAQ cards do have detectable glitching.
Make sure to consider the glitch energy level when choosing a device for your application.
To reduce the impact of these glitches, you can try the following:
  1. You can build a low-pass deglitching filter to remove the high frequency components of the glitch. Depending on the frequency and nature of the output signal, the low frequency components of the glitch may not be filtered. See related links for more information on deglitching circuitry.
  2. You can build an external deglitching circuit. The foundation of this particular idea is to use sample and hold circuitry to hold the previous value while the DAC is settling on the current value.
  3. Since the greatest glitch energy occurs at the midpoint transition of the output range (see the note in Additional Information below), you could try to avoid letting the output level cross this transition. Usually, the midpoint transition will be when the signal crosses 0 V. For example, rather than output a +/- 1 V sine wave centered at 0 V, you could output a sine wave between 2 and 4 V. The amplitude would still be the same, but you are introducing a DC offset so that the waveform never goes below 0 V. This should acceptable as long you are connecting the signal to a differential or non-referenced floating input.
The reason why DACs produce glitches, or small spikes is due to the released charge when physically switching from one voltage to the next. These spikes are typically the largest when the Most Signifigant Bit (MSB) is switched in the middle of the range of the DAC. These glitches are present in almost all devices that have a DAC on board unless the device has built in deglitch circuitry.
Note: The building of a deglitching circuit is not an easy task. Several schematics on how to accomplish this may be found online. In the past, NI has released some analog output cards (for example, the PCI-6711 and 6713) that include internal deglitching circuits. These greatly reduce the effects of glitches. To see if your device supports internal glitch removal, look for Glitch Removal in the specifications of the device.
NI provides high performance analog output devices which include onboard filtering, interpolation, and oversampling. These boards can output much cleaner signals than our standard DAQ products. If producing a glitch free, high performance signal is important for your application, refer to the NI's signal generators and DSA boards for analog output solutions.
