Multiple DAQmx Drivers on One Computer
Updated Jan 24, 2019
  • Can I run multiple DAQmx driver versions on the same computer so I can use DAQmx on different versions of LabVIEW? My two versions of LabVIEW require different DAQmx drivers to function.
  • I installed one version of DAQmx and then realized I needed an older version to be compatible with my LabVIEW version. Even though I've now installed the older DAQmx version, I still don't see it in my LabVIEW version. Why is this?
You cannot run multiple DAQmx drivers on one machine.  The newer version of the driver will replace the older version when it is installed.  To install an older version of DAQmx on your machine after you have installed a newer version, you will have to uninstall the newer version before you can install the older version.
However, it is possible to run DAQmx and DAQmx Base on the same computer successfully.
The reason you cannot run multiple versions of DAQmx is because they call from the same library that can only be accessed by one driver.
DAQmx Base makes calls to a different library than the normal version of DAQmx. The reason is DAQmx Base is a stripped down version of DAQmx that is meant to work on operating systems other than Windows.  It is also required for certain DAQ devices with limited memory.  It has limited functionality, and the code can only be used with other computers that have DAQmx Base drivers.
