Can I Change a Thermocouple Type On A Deployed cRIO Application?
Updated May 16, 2019
  • NI-9211
  • LabVIEW Real-Time Module
  • I have a deployed real-time application running on a cRIO-9074 + 2x NI-9144 expansion chassis. One of the expansion chassis includes a couple of thermocouple input modules (C-series modules NI9211 & NI9213).
  • It possible to change the thermocouple type (i.e. from J-type to K-type) for the modules without opening up the project and accessing the properties of the modules from the project explorer?
To change your thermocouple type, you will need to open the Module Properties window of your thermocouple module and select the thermocouple type for each channel. Once this is done, you will have to re-deploy the code to the cRIO.
