Cable Connected To My PCI Card Not Recognized?
Updated May 3, 2018
  • SCC-68
  • SHC68-68-EPM
Other
Windows 10
I have connected a NI SCC-68 terminal block to my PCI card via an SHC68-68 cable. Neither the cable nor terminal block show up in NI MAX. How do I get LabVIEW to recognize these devices?
Cables and terminal blocks are extensions of the pins on your PCI card and will therefore not show up as separate devices.
  • Run a Test Panel in NI MAX to validate inputs through your SCC-68
