This error message occurs when you try to open a VI that was written in a version of LabVIEW that is newer than the version of LabVIEW that you are currently using. You will not be able to view a VI that is from a newer version of LabVIEW in an older version of LabVIEW.
If you are attempting to open a VI associated with an RT and/or FPGA target after using the Save version feature in the project properties to save the project for a previous LabVIEW version, this error occurs because this feature is not supported for non-desktop targets as of LabVIEW 2026 Q3. VIs associated with LabVIEW Real-Time and FPGA targets can only be saved in the current editor version, regardless of the save version configured for the project.
If you have access to a version of LabVIEW equal to or later than the version of the VI (indicated in the error message), the easiest solution is to use the more recent version of LabVIEW. However, if you do not have permanent access to a more recent version of LabVIEW, you have a few options.
- Use a later version of LabVIEW to save the VI for a previous version of LabVIEW.
- For instance, if you received this VI from a colleague, have them revert the VI before opening it in the version of LabVIEW you will be using.
- If you do not have access to a version of LabVIEW capable of opening the VI, the Version Conversion section of our forum is an effective way to reach out to the community for help in reverting VIs.
